RCU Forums - View Single Post - Can you splice antenna wire?
Old 11-23-2003 | 11:38 PM
smitymax
Default RE: Can you splice antenna wire?
Yes, you can splice the antenna wire, just solder a similar wire to it and cut it the same length as the original, it will be some where near a total of 40 inches (for 72 mHz) Put a piece of heat shrink over it. Make sure you have a good solder joint after twisting the ends of two pieces together. Strip off about 1/2 inch of insulation off each piece.
