RCU Forums - View Single Post - Fox 45 throttle response
Old 11-24-2003 | 01:19 AM
DarZeelon's Avatar
DarZeelon
Default RE: Fox 45 throttle response
CropDuster,
Open the air-bleed screw slightly; about 1/8 of a turn at a time and retry to check the response.
An air-bleed screw is certainly not a "no low end adjustment possible" situation.
It is just a different way of doing it.
The OS.65LA has an air-bleed adjustment and it is by far better than the OS.61FX's "real" idle mixture needle.
Read the MAN 05/2003 engine shootout.
