RCU Forums - View Single Post - Can you splice antenna wire?
Old 11-24-2003 | 10:42 AM
Rodney
Default RE: Can you splice antenna wire?
Any length from 39 to 41 inches will work well. Your receivers all are base tuned (coil and condenser used in input circuitry) with the coil usually being a slug tuned item factory set and sealed. You won't be able to test any difference in range if you stay within those limits, i.e. exact length not real critical.
