RCU Forums - View Single Post - Futaba Rx JR Battery
Old 11-24-2003 | 12:19 PM
Krysta
Default RE: Futaba Rx JR Battery
Hi bipeflyr,
Since the receiver seems to be working for you, it might be okay, but since you did notice smoke, I would do a VERY thorough ground check before using this. I would really recommend that this be sent in so that the technicians can check this over for you.
The receiver is protected from reverse polarity causing heavy damage to the main board in just a case as yours. But again, I cannot stress enough that a thorough range check should be done each and every time before flight, if you are not going to send this to be checked.
I hope you find this information helpful. You can also reach our Futaba support technical team at 217-398-8970, or via fax at 217-398-7721.
Sincerely,
Krysta
Lead Futaba Customer Service and Programming Technician
Also you may want to check our Website at (http://www.futaba-rc.com)
