Kangaroo - how much reflex do you have?theare you
1/8" to 1/4" is needed for either Roo's based on the CG of your plane. I found the factory CG to be perfect with 1/2 fuel. If you keep the fuel on the CG as much as possible, your trim will not change much during flight!!!
Regards,Ehab.
