RE: Heavy Weight
Well the G 26 might not be 4lbs heavier but it got to be 3lbs heavier plus you must of had to add weight to the tail to get the CG correct plus the 26( though better than the 23) is still under powered for its weight. If you want to use gas its going to be a heavy plane.
