RCU Forums - View Single Post - JPO Statement
Old 11-24-2003 | 08:44 PM
  #383
mr_matt's Avatar
mr_matt
My Feedback: (10)
Default RE: Another "Fail safe" manufacturer to add...
How do you other manufacturers handle a normal shutdown?
I mean if you add this "failsafe" delay, won't that delay the time for an emergency shutdown? Imean if you use the radio failsafe, the ECU cannot tell the difference from a normal shutdown, right?
With the JetCat system, the delay ONLY occurs on a PCM failsafe, or a garbled PPM signal. Manual (emergency) shutdown is still instantaneous. Important safety item IMHO.
Does anyone know what the TRC intended? Are all shutdown (including manual emergency shutdowns) to have a delay?
PS Mark how could I forget about you!!
