RCU Forums - View Single Post - JPO Statement
Old 11-24-2003 | 11:13 PM
  #389
c/f
Default RE: Futaba Failsafe Behaviour.
Kevin Green,
Lets try this another way since you may have not understood my first post. Lets say your 3 position switch for AMT run mode is channel 8, simply go into code#77 and set channel 8 for Fail Safe verus Hold, Then set the switch for channel 8 in the Emergency off position prior to hitting memory. Thus when it goes into hold the radio will shut down the turbine.
What objective am I misunderstanding that you are trying to achieve that this does not address?
Tom,
Perhaps Jr moved it into the factory setup screens, Ill get my cheat sheet tommorow and check around in there.
