RCU Forums - View Single Post - JPO Statement
Old 11-25-2003 | 07:02 AM
  #391
Silver182's Avatar
Silver182
Default RE: Another "Fail safe" manufacturer to add...
ORIGINAL: diceman
Let me start over.
I believe that a radio enduced failsafe shut down is not appropriate. I also believe it's not safe. I believe a low throttle setting, extend the gear failsafe reaction is appropriate and safe.
My concerns center around the radio systems not the engine ECU's. Most radio systems sense failsafe in a few miliseconds +/-. The JR radio is the only radio system that I am aware of that allows the user to set the length of time after sensing the failure, interference, loss of sig. etc before the failsafe actions take place. I believe it's up to three seconds.
Any of us who fly with pcm equip. in other planes, sport or otherwise experience failsafe from time to time and never know it. It happens so quickly it's not noticeable. Now apply that to the other radio equipment and see what happens.
It's my understanding that all the other radio manuf (except JR) that produce the equipment suitable for what we do, have failsafe systems that do not have a deelay. This would mean under the proposed guidelines begining in 2005 that a very brief 1 second failure will cause an engine shutdown. To me this is not safe, and will cause more problems than it would ever solve. Not to mention the potential loss of a airplane for no reason.
I hope this explanation is a bit more clear.
Re-read the proposed regs. --- the delay required is 2 seconds is it not in the ECU/turbine?
And check your JR Radio out ----- Transmitting to an S mode receiver the 10X's failsafe is "INSTANTANEOUS NO TIME Delay" -- allowed the biggest problem I have with the JR 10X. JR is one of the main reasons the ECU's were reprogrammed for fail-safe time delay. 10X transmitters do allow failsafe delay up to 1 sec max. if you are transmitting to the older 512 bit PCM receivers! Screwy huh-----
Lee
