RCU Forums - View Single Post - FUJI BT-32A engine
Old 11-25-2003 | 10:48 AM
Bax
Default RE: FUJI BT-32A engine
Fuel/oil mix for the Fuji gasoline engines must be at least 40:1. 50:1 is a bit short of oil.
The main problem with hand-starting is getting high-enough speed to allow the magneto to give a high-enough spark. The engine should be choked so that it's quite "wet", and spitting a bit of fuel from the carburetor. A very brisk flip should allow it to fire.
If you cannot obtain the spring starter from your engine, it can be ordered from us:
FJIG1032 9400068 SPRING STARTER BT-32A US$79.99 + shipping.
