RE: Is buzzing called servo binding?
Best fix would be to slice through the hinges and beside them, install Robart hinge pins or nylon pinned hinges, which are not expensive. The CA hinges are just to stiff. The nylon hinges, properly installed, ailerons will flop down from their own weight. Also stiff hinges will use up batt power quite quickly.
