RCU Forums - View Single Post - Inverted Flight
Old 11-25-2003 | 07:53 PM
CarolinaCrasher
Default RE: Inverted Flight
Yes it should remain fairly level. You might have to hold a little down elevator, but not much. Mine will stay level inverted with very little down elevator put in. If you want you can move the CG back and this will help a bit, but if you don't want to do that and it doesn't require much correction then I would just let it go and manually hold it level.
