RCU Forums - View Single Post - Evolution engine, Need commend
Old 11-26-2003 | 02:39 AM
The_Matrix
Default RE: Evolution engine, Need commend
Joe,
You probably don't know this, but it's in your manual under the Evolution Power Train System. All evolution engines are already broke in at the factory, and needle vaulves are preset. that's why the evolution engines do not require breakin when you purchase one, or purchase a plane with one pre-installed in it such as the Extra Easy 2. You made a great choice on your trainer, I started with the same setup, EX2 with evo power trainer system, and was easy plane to learn with. Was able to start landing and taking off after only 3 short lessons. Once you are able solo with it and feel you are ready for your next plane, (start getting bored that is), save your money and do some tweaking to the EX2, such as changing the servo arms and adjusting linkages to give you maximum throw, ditch the 3 blade prop and goto a 10x6 2 blade for more speed(although you won't need it), it will be like a totally new plane again, and will increase your flying ability before moving to your next plane. Not to mention it will refresh the excitement. You will be surprised at all the maneuvers you will be able to perform after making adjustments, acrobatic and otherwise, and yes with a trainer. Hope you enjoy it bud.
