ORIGINAL: torquerolln
Tom can you take a pic of your setup with the DA50. How many servos did you use on the rudder. Did you use two 5945s or one 5735(i think) the one that weighs like 5 oz. If so, did you mount them in the back of the plane or inside the fuse. And another question>is there room for a smoke system or no?
Thanks in advance
dan
I am using one of the new JR 8611 servos for rudder, as much power as the 5735 and less weight. It is mounted inside using pull-pull.
There is a lot of room between the motor box rails, a smoke system shoud fit easily.
Tom Fawcett
