RE: Setup with Moki 2.10
Tom,
It appears to me if I wanted to mount a Moki 2.1 on the Edge I would need to add a box or some type of spacer to get the proper distance from the firewall to the front of the cowl. Would you agree? Keeping all the servo's in the front and using Pull-Pull would also seem to be the way to rig given the overal added weight of the motor system would probably be less. I would appreciate your comments and suggestions.
Jerry
