Pizazz Wing Attachment
Sure, go ahead and give me the specs on the throws, I usually start out low and work my way up. I like the set-up of the SE way better than the Pizazz, there's not a lot of room to get the servos in the bottom and snake everything through, the gluing of the wing was also a drag, mine had gaps in the top the glue did'nt even come in contact with, which makes me a bit concerned how airworthy this thing will be. The stock landing gear is also freakish with its high stance. Needless to say, I'm not real happy with this plane, along with the missing instruction pages, the slot for the horz. stab was too small and it did not fit without some surgery. I was debating on an electric 3D plane when I bought this set-up with the Saito .72, and probably should have.
Thanks.
