RCU Forums - View Single Post - CA Techniques
Old 11-28-2003 | 08:31 AM
rajul's Avatar
rajul
Moderator
My Feedback: (58)
Default RE: CA Techniques
ORIGINAL: Tmoth4
A great technique I picked up from the Balsa USA instructions is to glue the parts together (balsa or ply) with the thicker Ca+, then go back over the joints with thin Ca. This makes a very strong joint. If there's any gaps I go over those again with the thick Ca.
Jim
Hi Jim, Does the instruction say to apply thick ca on the mating surfaces first, then assemble ?
If the balsa parts are assembled first, then glued, I would recommend running thin ca first.
