RE: Jamara Spitfire60 ARTF
If you do opt to pin your hinges one method is cocktail sticks. Merely make a pilot hole with a pin then drill a 1.5 - 2mm hole, insert the stick with a dab of cyano then cut off with a sharp blade. Don't forget to fuel proof the top of the sticks!
