RE: 3 line tanks - 3rd line bend tubing or use tubing with clunk?
i use no clunk on the fill/drain line. i bend this tube down to 90 degrees then put a piece of tubing on it so it just touches the bottom of the tank. i cut a small "v" on the tip so it won't suck itself to the tank bottom when draining.
