RE: Balancing blades on aerohawk
check your CG should right at the main shaft, too much tail heavy can cause this, move your batt forward
check the shape of the two blade, mark to identify which is left or right then twist one of them and see how it effects at a time. when you look at the side view the two blades spin at the same tip level, this OK
I found that for skylark, dragonfly dont need to balance the blade like the big heli.
