RCU Forums - View Single Post - Arising star engine mount
Old 11-29-2003 | 07:44 AM
tomsecret
Default Arising star engine mount
I've just started building an ARTF called Arising star. However, the engine mount doesn't seem to fit my engine. The engine is supposed to be fixed by 4 screws. The distance between the holes on the engine mount and the engine isn't the same, on the engine the difference between the two holes is about 2 cm, while the distance on the engine mount is 4 cm. Is it enough to fix the engine with two screws (one on each side)? Or should I replace the engine? The engine is a SC40A (Aero RC ABC Engine (MkII)). As you can probably tell I'm a total newbie I have only used an electric slow-flyer before, this is my first glow engine aeroplane.
Thanks for you help!
Tom
