RCU Forums - View Single Post - help with my hype3d
Old 11-29-2003 | 09:15 AM
stomper
My Feedback: (20)
Default RE: help with my hype3d
ORIGINAL: caliber302003
hi all ive ran into a bit of a problem on my hype3d. what it is i cant seem to find out which way the tank goes up as there is such ample space do you guys just bung it in and fill with foam or is there some sort of way it has to go some pics would be a great help
many thanks
I just cut 1/8" lite ply to the inside width of the fuse about one inch wide, two on top and two on the bottom with just enough space to shove some foam between tank and lite ply. This way you can control the hight of the tank to the carb.
This an awesome plane!!!! Best of luck with yours.
