RCU Forums - View Single Post - High winds and a stalling engine...
Old 11-29-2003 | 12:52 PM
Flypaper 2
Default RE: High winds and a stalling engine...
Airbleed screw is only for idle adjustment, but do as Jim says and hold the nose up and set the high speed needle till the engine goes to top rpm., then richen it up till you hear the engine slow down a couple of 100 rpm. As the tank level drops the engine will lean out even more. It should be so that when you get to the botton of the tank, it is leaned right out.
