RCU Forums - View Single Post - Few Sig wonder ??
Thread
Few Sig wonder ??
11-29-2003, 06:15 PM
2
SALMONBUG
My Feedback: (
1
RE: Few Sig wonder ??
Hi,
Don't be too concerned about the metal metal on the ailerons control rod.
As soon you don't install more than a .15 engine you are ok with hs81 on all controls
one of my wonder on .15 size is 4 years old with those servo (more than 400 flights)
as you can see on the following pics, wonder speed up your imagination.
I suggest you to fly your first flights with cg at forward limit and recomanded throws (hig rate), because the wonder is a bit diferent than what u fly usualy
you may want to add tri stock to glue the stab on the fuse, that's the weak point of the plane.
make your first one as per plan to feel confident with the plane and then switch to a other one with operational rudders and .25 engine
you will LOVE it
here are two of my wonders
Reply
Like
SALMONBUG
View Public Profile
Send a private message to SALMONBUG
Find More Posts by SALMONBUG
View iTrader Profile
