RCU Forums - View Single Post - Model Tech P-47 engine?
Old 11-29-2003 | 06:48 PM
  #32
meatball1
Default RE: Model Tech P-47 engine?
I THINK THAT IF YOU USE A .60 IN YOUR MT P-47 YOU WILL NOT BE HAPPY WITH IT'S PERFORMANCE AS A FIGHTER.I HAVE THE MT P-47 ALSO AND FLY THE HELL OUT OF IT WITH A GREAT RUNNING AND SOUNDING MAGNUM 4 STROKE.FIT GREAT INSIDE COWL MOUNTED ON IT'S SIDE WITH EXH POINTED TO THE GROUND.A LITTLE CUTTING OF COWLING FOR ENG VALVE COVER AND ON BOTTOM FOR EXH STACK.ALSO VENT THE REAR OF COWL TO VENT HEAT. ONE OTHER THING THAT YOU SHOULD CONSIDER IS TO USE LARGER WHEELS ON MAIN GEAR.YOU CAN CUT THE WHEEL WELLS EASY ENOUGH TO ACCOMMADATE. PROVIDES A LITTLE MORE CONTROL IF FLYING OFF GRASS FIELD AND LOOKS BETTER. THE MT-47 ALSO LOVES TO NOSE OVER ON TAKEOFFS SO REMEMBER TO HOLD FULL UP ELEVATOR UNTIL TAIL COMES UP AND YOU GAIN ENOUGH SPEED FOR ROTATION.GOOD LUCK,GIV'M HELL
