RCU Forums - View Single Post - Setting up blimp thrusters
Old 11-29-2003 | 11:52 PM
bent
Default RE: Setting up blimp thrusters
I'm still on the learning curve too but we'll all be experts soon. The challenge for me is smooth, slow cruising without porpoising and rock steady hovering. I find it's a much nicer flier if you reduce the extra weight in the ballast bags as much as possible. I don't fill the blimp completely with helium. While filling, once it's lifting all the attachments and payload, I top it up with blown air from a vacuum outlet. This keeps the ballast weight to a minimum. Haven't tried dropping anything yet. I understand one t-shirt at a time is the limit for this size blimp. You might want to try putting a helium filled balloon inside the t-shirt to reduce the load...maybe it would allow multiple drops per mission.
