RCU Forums - View Single Post - This Long Shaft!
Old 12-01-2003 | 11:34 AM
av8tor1977's Avatar
av8tor1977
Default RE: This Long Shaft!
Yes, that will work. The shaft is not as hard as most people think, and is "hack sawable". I sometimes use a dremel with a cut off wheel, and go slowly. On some of the engines I do, I need to cut the shaft off in the back and if I cut it with a hacksaw it leaves a good bit sticking out to grind off so it is below the level of the crankcase to airplane mounting area.
Good luck,
AV8TOR
