RCU Forums - View Single Post - Is anyone experiencing interference ?
Old 12-01-2003 | 12:52 PM
3dnut
Default RE: Is anyone experiencing interference ?
This problem could occur do to the antena touching any of the push rods on the plane if so re route you antena also check all your connections and check if your transmitter antena is loose. and try a range check walk away from the plane about 50 feet with the antena down and see if the problem occurs again if so its either batteries not fully charged or antena on trans or receiver. will
