RCU Forums - View Single Post - This Long Shaft!
Old 12-01-2003 | 01:43 PM
w8ye's Avatar
w8ye
My Feedback: (16)
Default RE: This Long Shaft!
I'm not sure what's going on here but I thought he was talking about the longer shaft on the flywheel end of a weedie that was used to accomodate the clutch on some models? The point where you cut this long shaft off is close to 3 inches away from the seal.
The concern about heat getting into the seal concerns the double ended engines (mostly chain saw types and I think the Kioritz he was talking about) whereby there is a shaft sicking out the back end of the engine that must be sawn off.
There's another tidbit and that is on a Homelite 25 for example, there is a different flywheel on the long shaft engine compared with the short shaft. Being as one has a 3/8" shaft and the other a 5/16", The taper on the crank is a different size. The flywheels will interchange but it causes the flywheel to be too far forward or backward depending on which way you are swapping parts?
Enjoy,
Jim
