RE: Converted Y/A F-16A to from DF to pusher
If it'll fit look at the new Webra 120 w/pump. Pricewise it's not too bad...around $235.00 and you can use the same set up as the 45 (with the tanks on the CG) and spin a 12-14" pusher prop if you have enough clearance.
Tom
