RE: Regulating Smoke Fluid
Yea!
You need to regulate the flow. I'm surprised that your pump didn't come with some type of regulator. I use a simple method, I just drill a hole in a piece of dowel, and tap a thread perpendicular to the hole. Then I just run the oil line through it, and squeeze the line with the screw.
