RE: Jet Pipe Question
It's my understanding that what makes a dual wall pipe work so well, is the fact that the inner pipe is shorter at the back than the outer pipe. This helps draw air between the 2 pipes. The same is true of the fuselage. The outer tailpipe should be a little short of coming out of the fuse, to help draw air out of the fuse. Is this correct?
