RE: Changing Head on OS .91 VR-DF
Not a big deal, but the shim is brass and may not seal perfectly if re-aligned, particularly if it has seen a few removals already. New head shims are cheap. By the way, if you have trouble with idle, I have found that adding a second shim can help. Regards, Keith.
