RE: Engine tunning
I don't know half of what these other guys do but I had a similar problem. It would run great on the bench, take off and die. There was also intermittant problems with transition. It turned out that I had an air leak around the bottom seal where the carb plugs into the engine. You also might check around the barrel of the carb for bubbles. Just a thought, but it's part of what my problem was.
Rick
