RCU Forums - View Single Post - Flaperons?
Thread: Flaperons?
Old 12-02-2003 | 06:16 PM
combatpigg's Avatar
combatpigg
Default RE: Flaperons?
All you are doing is programming your radio to make the ailerons behave like flaps when you use the elevator . when you move the elevator up, the ailerons should go down. Make sure that your end point adjustments are accurate,if the flaps don,t move an equal amount you could be in for an interesting flight. Flaperons will open up your flight envelope, and they even saved a plane for me once when the elevator servo went out.
