RCU Forums - View Single Post - ultracote
Thread: ultracote
Old 05-12-2002 | 01:25 PM
Homebrewer
My Feedback: (8)
Default Covering
Just make sure you have about 1/4 inch overlap. Don't overheat the seams when covering because it will shrink and pull away from the seam and expose wood. Other than the overlap, I don't do anything else, ultracote is good stuff and won't pull away on its own (unless heated by an iron/heat gun, the glue in the covering allows the covering to be adjusted/removed/reapplied).
