ORIGINAL: jbfoster
If I increase pitch will I get more pulling power(more vertical) and less speed in level flight ?
If I lower the pitch less vertical and more speed in level flight ?
What would be the effect if I increase pitch only , lets say a 10X6 to a 10X7 ?
What would be the effect if I change Prop length only, let's say a 10X6 to a 11x6
What about both, a 10x6 to a 11x7 ?
Jim
I think you got backwards Jim, more pitch gives you top end speed with sluggish vertical or static thrust. Less pitch and bigger diameter would work on the opposite fashion.
