RCU Forums - View Single Post - Idle problems
Old 12-04-2003 | 11:24 AM
Darryl Usher
Default RE: Idle problems
You can pull the throttel and it will spring back a lttle, most all do.
If the rachet is on top of a tooth it will move to the bottom.
You can fix this by having the sevro wheel all most over center at low, this makes low speed adj. easy.
Darryl Usher
