RE: TOWER FUN 51 ENGINE
hi got the book .
elevator high rate.7/8 up and down . low rate 1/2 up and down.
rudder high rate 1.3/4 both ways. low rate same as high rate.
ailerons high rate 1 up and down. low rate 5/8 up and down.
CG IS 3.3/8 FROM LEADING EDGE. IT SAYS YOU CAN TRY 1/4 INCH EACH WAY AFTER YOU GET USED TO IT.
