Futaba/JR
Had same problem a few years ago on a JMP T-33. Try using a JR Y connector with the amp for the JR sevos at the end of a long lead. The JR AMPLIFIED lead will change the futaba 3.3 volt signal to 5 volts that the JR servo is expecting. Stopped the jittering with this aircraft
Nat
