RCU Forums - View Single Post - Does(do) MAH's make up for Voltage?
Old 12-05-2003 | 04:19 PM
Rodney
Default RE: Does(do) MAH's make up for Voltage?
If you have submarginal wiring (too small a gauge and/or very long leads) the voltage drop in the wiring is what gets you in trouble. Use heavy duty wire (at least 20 gauge) with gold plated connectors and heavy duty switches and you should be okay with either 4 cell or 5 cell batteries. Keep all leads as short as possible.
