RCU Forums - View Single Post - Yak Attack!!
Thread: Yak Attack!!
Old 12-05-2003 | 06:41 PM
ChuckAuger
My Feedback: (12)
Default RE: Yak Attack!!
ORIGINAL: TERMAGATOR
LOOK at the size of dim dare AILERONS!!!!
Them ain't your daddy's ailerons! If you look closely in the second pic, you can see the Trident with modified ailerons under the Yak. I liked the way the Trident flew so much better with dem dare bigguns, I made the Yak ailerons the same size (basically..) And the size of what was left of the Trident wing after I cut 1 1/2" off the hinge line is almost identical to the Yak wing. So they have a very similar wing/aileron ratio. Ought to be right perky
