RCU Forums - View Single Post - GP CHRISTEN EAGLE
Old 12-06-2003 | 12:02 AM
  #81
rfw1953
Default RE: Hinge update
Hoss, The directions for the Pitts stated that you should put the two machine screws in the holes at the top of the Cabane struts and then position over the pre-tapped holes. Don't tighten just make them snug. This way you won't get the alignment wrong when using the pre-tapped holes. The holes are simply a positioning point. If you mount the cabanes joined together, this will guide the wood screws in place as you finish tapping the holes with the larger screws. I started each screw and then turned a few turns and then went to the next screw. Did the same until I had them in place. This helps to avoid getting the alignment off. Check the directions for the CE. I would think G.P. would list this direction point as well for the CE. If the holes are way off then of course this won't help. I did this wrong on Pitts-1 and had to plug one of the holes with a dowel pin and epoxy and then re-tapped with a new hole. Always something.
Texas-3D - I was fortunate to have someone recommend Aerografixs to me as well. Roger is a really great guy and he does beautiful work. I'm confident you will be pleased. I used a True Turn with the DA 50 and had them cut the spinner back plate for the four mounting bolts. They also cut the slots to match the Menz 22 8 prop. I have read where guys do this on their own, but for the minimal charge it sure seemed worth it to have True Turn do this for me.
