Fox Racing glow plug ?'s
Is anyone familiar with these plugs? They're the long version with the idle bar.
Problem: When I put my heater on them, the coil doesn't get hot. I've tried four different ones at different settings on my power panel from low-med-high.
Even put a drop of WD40 on the coil just to see if it'd smoke. NO.
They're NIP. When adjusting the voltage on the other plugs, you can see it glow hotter. But with these.... [:@]
Btw, anyone got a good starting point with the needles on the OS Max 60?
