Weedeater Engine Conversion
Good job,
Be fore-warned that there are actually a lot of diferences in Homelite 25's and/or 30's
The 30's cylinder is most likely held on with #12 self thread rolling torx screws. While the 25 has #10's
The electric version has a compression release on the intake side as well as the EGR port on the exhaust side.
On the crankcase, the deck heights, and the position of the back plate flange varies by a pretty good tolerence.
Some back plates are steel.
you can use either the tapered seat or the gasketed plug in them. They seem to run the same with either.
see you there
Jim
