RCU Forums - View Single Post - Turbine mounting What am I doing wrong
Old 05-13-2002 | 09:01 PM
bkf
Default Turbine mounting What am I doing wrong
Ok then I guess it is mounted the way it should be. That bottom screw is in the same place as yours. Does yours tilt a bit when you pull up on the nose cone (same as full power) Thanks for the pic it helped alot. Ken
