WM: So you think the butt should be up a bit (for making the nose want to rise with power?) Yep having the turbine closer to the CG does make sense. With the Ram 500 it would be nose heavy. With the JetCat way back it might end up tail heavy. I won't add non functional weight. Makes no sense. Things can be moved around. Ill look at JetBlue. I got a room at Quinte for next month. I hope Tam's event turns out REALLY GOOD. He deserves it. Maybe they will send me a jar of the secret cocktail
K
