RE: what/how do you fly in the winter?
if you can build, get an aqua star, its POS but it wil lfly off show with no skis flies off water looks good too. (warning, not a first time build the instructions suck and the plans are about as bad, but if youve build one plane b4 you cna do this)
its cheap and flies wiht std servos and a .061 engine (my preference) but will fly .049-.071 (small eh?)
no ailerons though, but if your into the idea and have knowage to do so, you can add them but i recomned going to micro servos if you do.
also, if you do build it FIBERGLASS THE HELL OUT OF THE ENGINE PYLON
that is the most poorly designed part.
or you could get the GP version but ive never built and gant speek from experiance on that 1.
you could also scratch a micro lite indoor flyer real easy, small light wings and a stick for fuse, cant be esier. (MUST use micro servos and electric engine.)
