RCU Forums - View Single Post - Adding Charging Connector to Futaba Transmitters
Old 12-07-2003 | 01:25 PM
oldtyme
Default Adding Charging Connector to Futaba Transmitters
Hi,
I have 3 Futaba transmitters. Because of the diode protection between the charging jack
and the battery, it is impossible to cycle the battery in the radio. In the case of two radios,
it is very hard to remove the battery because the leads go behind the case and the connector is not accessable. I have installed a "J" connector between the battery termination and the circuit board so I can cycle the battery in place. Will this harm the
circuit board if the power switch is in the "off" position and will this work?
Andy
