RCU Forums - View Single Post - Kioritz 23.6cc vs. Homey 25cc
Old 12-07-2003 | 04:12 PM
av8tor1977's Avatar
av8tor1977
Default RE: Kioritz 23.6cc vs. Homey 25cc
Well, just got through running the little hot rod Kioritz, and it runs great. I was hoping for a little bit more power than I saw, but then I really haven't tinkered with fine tuning it much, and it doesn't have much time on it either. (Like maybe 20 minutes.) Even so, it put out 20 to 25% more power than my modified Homelite. More power, and 1/2 pound lighter. Can't beat that!!
The density altitude here today is 6500', and the Kioritz turned an APC 16 x 8 prop at 8200 rpms. At this density altitude, the engine is down about 20% in power compared to what it would have at sea level. It should turn the same prop over 8600 at sea level. That's a little less power than Keith from BME got, but as I said, it has very little time and fine tuning on it. As it gets some more time on it, and I experiment more with the timing, carb, mixture, etc., I believe it will gain a bit of power. Still, it's pretty impressive as it is!! I'm happy!
Take care,
AV8TOR
